lower control arm rx330
Hi, please need help
my car is RX330 2004 with around 59000 miles, went for auto inspection and failed, they said the lower control arm need to be replace. They ask for $350 for 1 side (oem parts). I think the car runs fine and please advice if the lower control arm really need to be replace,
thank you
thank you
It does look worse for the wear friend. Mine went out fairly early too. It is not an expensive fix. Purchase the control arms, or the bushings.
Loosen the FRONT LOWER engine mount, but do not take bolts all the way off. Allow for play which will be needed. You can then Loosen the bolts for the side engine mounts, etc. etc.
It is not hard, just a lot of bolts to loosen. Obviously take off car tire. You will have to REMOVE the side mounts in order to remove the lower contorl arm.
Then have the bushings replaced or simply replace the control arm as a whole.
Bottome line, yours look bad. If they are not already torn through, they will be soon!
You can thank that wonderful **** they put on the roads up here in the winter time....
Ruins everything. What I really cant understand is where are the Tree hugger`s when it comes to stuff like that? As far as your original question, yeah I would replace them.
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
I ordered these for under $100 for both sides http://www.ebay.com/itm/261264681679...S:1123&vxp=mtr
I am in AZ and about to do the same repair, so I think the salt may not have much to do with it. I replaced the rotors twice until I came searching on this forum for another reason why streering wheel wobbles on decal.
Changed struts, mount and control arms. No wobble now on 15 min test ride. Took over 10 hrs to do job with a lift. I am not fast and had help. Probably take 6 hours now to do complete job after screwing with sub frame bolts and the spring tool for new strut.
Hi,
Anyone know an official DYI with pics for this?
Bigdog100, is the Dorman control arm allright? Compare to the Blue Print etc. the price is so different. If they are ok I might get them too.
I just replaced the right side control arm.
Jack up car, place jack stands and remove tire.
1) Removal all of the nuts that are holding the motor mount.
2) Remove the nut and bolt that is holding the control arm bushing on.
3) Remove the nuts and bolt that are holding the ball joint on.
4) Remove the two nuts that are connected to the transmission mount.
5) Place a piece of wood on your jack and jack up the engine at the oil pan. Keep jacking until the motor mount is clear of the bracket.
6) Remove the motor mount, then remove the two bolts that are attaching the arm to the frame.
Good clip to watch:
Good clip to watch:
HarborAreaTech (03-02-24)
HtownBlue
08-13-12 05:09 AM
OutlawTita
Suspension and Brakes
05-22-08 01:07 PM
