P0137 sensor location
Hi guys, need a little help with a rx330. Car threw check engine and vsc light. Error code p0037 b1s2. I've replaced sensors on my is300 and rx300 but can't find anything on the rx330. Popping the hood I only see 1 sensor. Can some please let me know where b1s2 is located or a how to? TIA
thanks for the diagram. My apologies but I was mistaken and wrote the code as p0137 but it is p0037 b1s2. Still the same bank and sensor so this should help. I plan on using a universal O2 sensor because the location of the sensor connection looks to be inside the dash console and will be a pain to get to. If you have a universal (cut/splice) type O2 sensor to recommend I would appreciate it.
Thanks guys you've all been super helpful. I see where the connector is located and it should be an issue. I ordered the denso universal as I do not kind splicing and all 6 sensors I've done in the past have used the universal. Yeah it's half the price, I'm a cheap ***. Thanks again everyone I appreciate all the help.
