Tackling Mt. Everest: Timing Belt/Water Pump change (***DIY w/ pics***)
Old 04-06-14, 04:06 PM
alchemist
alchemist's Avatar
Default Tackling Mt. Everest: Timing Belt/Water Pump change (***DIY w/ pics***)
First, big props to other members for their input on this - HTOWNBLUE, gscott2, luvrxxx, thomas1 and I'm sure others. Their threads were helpful as well as the RX300 TB videos on youtube. Also, feel free to use this thread as a catch-all for TB and water pump related questions.
Below is my experience in doing this. I would rate it on a scale of 1-10 with 10 being most difficult probably a 9. It is not for the faint of heart – you can really mess things up but I hope my instructions alleviate that concern. I had no issues throughout the entire install.
I would allow for two days to do this. Similar to my spark plug write-up, first day tear down and install new belt, then second day install water pump then put everything back. I will skip a lot of basic details of removing things unless a specific method is necessary or I found a shortcut. This is probably one of the biggest maintenance-related jobs on these cars. It is recommended to do at 90k miles. I did ours at 120k and the belt still looked new (see pics). Could have easily gone to 150k miles.
Disclaimer: Attempt at your own risk. This is the method that I found most useful and efficient – yours may differ and may not be the exact as described herein. As with any do-it-yourself project, unfamiliarity with the tools and process can be dangerous. This project should be construed as theoretical advice.***I will not be held responsible for any injury or engine failure due to the misuse or misunderstanding of this DIY project****.
****Due to sheer file size and numbers of pics, the DIY is located in the attachment below*****
Please let me know if there is a better way to upload. File is a 61-page PDF (35-36mb).
LET’S DO THIS!!!!!…..
Mediafire:
https://www.mediafire.com/?5z34er60l728571
or
Megafileupload:
http://www.megafileupload.com/en/fil...iteup-pdf.html
The following 2 users liked this post by alchemist:
JBSGROUP (10-12-23), Margate330 (03-13-20)
Old 04-06-14, 04:54 PM
Rainbird
Rainbird's Avatar
Great posting, makes me glad I bought a 2007 model with the timing chain. The only thing I would change is removing the wristwatch when doing this work.
Attached Thumbnails Tackling Mt. Everest: Timing Belt/Water Pump change (***DIY w/ pics***)-06-tb.jpg
Old 04-06-14, 05:02 PM
mandyfig
mandyfig's Avatar
Awesome! We appreciate this kind of endeavor! Thank you.
Old 04-06-14, 06:57 PM
alchemist
alchemist's Avatar
haha no doubt. That's my friend. He'll never take his watch off. lol
Old 04-06-14, 06:58 PM
alchemist
alchemist's Avatar
No problem. Are you going to tackle this now that you've done your plugs?
Old 04-09-14, 09:24 PM
alchemist
alchemist's Avatar
I made some updates to document as i found a couple mistakes
Old 04-10-14, 10:03 AM
kickin8
2IS/2RX/4RX
kickin8's Avatar
Thanks for sharing!
Old 04-10-14, 10:38 AM
kevs98GS4
kevs98GS4's Avatar
so 07+ models have a timing chain????
Old 04-10-14, 11:24 AM
alchemist
alchemist's Avatar
Yes. In 2007, the 3.5-liter 2GR-FE V6 went to a timing chain. My 07 GS350 has a chain as well.
Old 04-10-14, 11:28 AM
kevs98GS4
kevs98GS4's Avatar
sweet! REALLY glad to hear that. Finalizing a purchase tomorrow and that makes me feel much better!
Old 04-10-14, 11:39 AM
alchemist
alchemist's Avatar
You're in the clear. You'll sell the car before it needs another chain.
Old 04-11-14, 03:19 AM
tomit
tomit's Avatar
Just make sure to keep the cooling system in good shape. Changing the water pump is mucho expensive on the 350s.
Tom
Old 04-11-14, 05:40 AM
alchemist
alchemist's Avatar
Tom
Youre absolutely correct. My GS350 water pump started leaking at 90k.
Old 04-11-14, 08:04 AM
Rainbird
Rainbird's Avatar
My water pump on the 2007RX had a leak at 60K. It was replaced at no charge by Lexus under the power train warranty.
Old 04-11-14, 08:37 AM
alchemist
alchemist's Avatar
Glad it was taken care of. I was out of warranty but fortunately on the GS, it's not that bad to do:
https://www.clublexus.com/forums/gs-...with-pics.html
Quick Reply: Tackling Mt. Everest: Timing Belt/Water Pump change (***DIY w/ pics***)
