2005 passenger side cup holder
Hi all, does anyone know where to getthe passenger side cup holder that matches the on the drivers side beneath the side vent? Also is it easy to install?
thanks in advance.
thanks in advance.
Some guy did it about 2006 on a 400h. Got the part from japan about 200.00 it was a major project. I tried to find the place that sold the part with out luck. try to search here or lexus owners club to see what you can find.
Fellow member infinirx did it to his RX when he had it. I know that he has since sold his RX and moved up to a 1st gen GX. He hasn't been active in about a year, but you might want to look through his threads. I remember that a lot of people asked him about it, so he went into some detail as to how he did it. If you can't find anything, maybe try PMing him and see if he replies.
Link to his profile
https://www.clublexus.com/forums/mem...-infinirx.html
Link to his profile
In the RX (Harrier) model, the union between the A/C pipe (don't know the technical term) and the vent is larger at the passenger side (right side for LHD and left side for RHD) than the driver side. This is a problem because Toyota only made this fancy vent for the "driver" side. I can't tell you with any certainty if the routing for the pipe is identical, but if you look at the blow-out parts diagrams, besides the pipe "shape," the vents appear to have the same runs and turns. I wanted to do this mod, too, but have decided not to because the vent is pretty expensive for a singular piece, and I didn't like the idea of possibly opening up a leak source by trying to fit this together.
MSterling
ES - 7th Gen (2019-present)
09-26-18 07:28 AM
