Rethinking the "Load carrying capacity reduced" yellow sticker
This is the sticker that is pasted inside the driver's side door of third generation RX 350's and the RX 450h. There has been some comment on these lately to perhaps being related to newer, softer springs being installed to reduce the harshness of the ride perceived by some people. Yet the sticker reduction weight seems to be a different number for each vehicle. Shouldn't the rate of reduction be consistent if this change were due to softer spring dampening and therefore the total lbs. reduction the same for each vehicle?
In rethinking this, I think this number is uniquely derived for each vehicle based on the weight of options installed either at the port of entry or during final assembly based on the unique options on each car and has nothing to do with modified spring rates designed to soften the ride. This would explain the variations of each yellow sticker based on the added weight of the particular options installed. Just a thought.
I believe this is a useful thread. I too don't care about carrying capacity itself unless it were a lot... My take is the original intent of this thread is trying to tie some independent thoughts together (running in other threads) about if the reduced carrying capacity "yellow sticker" is part of the puzzle correlating to a noted improvement in the ride many have found on 2012 and 2013s with 19" wheels. Like others, I suspect seeing what's different on the 350/450h and different MY stickers may be part of the answer determining what Lexus did to the 2012s and if there have been further changes to the 2013s.
Exactly Bert. That was the intention of the post. I know nobody cares about the reduced load carrying capability of the vehicle, myself included. The post is an attempt to discern whether Lexus modified the springs to soften the ride based on feedback by some owners regarding a perceived harshness in the ride. My yellow sticker says an 11 pound reduction. The range seems to be 0 pounds to 90 pounds, with no two alike between the extremes.
My conclusion is that the wide discrepancy with no two being alike is a function of unique optional equipment added to each vehicle and has nothing to do with any suspension modifications on the part of Lexus. For some reason, owners of the hybrids seem to have a larger load carrying reduction.
I believe it is significant enough for me because it has reduced my capacity to 795 vs 885. That could mean the difference by one less occupant.
The load carrying weight reduction of the yellow stickers should not be significant for most drivers. The following represents the headroom available, that is, the weight payload for the 2012 Lexus SUV's obtained from a google search. The weight payload is the difference between the GVWR(Gross vehicle weight rating) and the curb weight of the vehicle:
2012 LX 570 - 1384 pounds
2012 RX 450h - 1322 pounds
2012 RX 350 - 1301 pounds
2012 GX 460 - 1260 pounds
These numbers are before car option weights and occupant weight and do not account for weight distribution.
VVRX, the yellow sticker on my 2013 Rx450h says capacity is reduced by 91 lbs. Do you have the Tow Prep Pkg like me? I also added the hitch. The tow pkg adds some extra stuff including heavy duty alternator and radiator, aux transmission cooler.
