2007 RX350 Door and turn signal wiring diagram
Does any one have access to wiring diagram for the door and turn signals for 2007 RX350? I am in the process of installing LED turn signal mirrors and trying to figure out where to tap the wires.
Any help is greatly appreciated
Nomi
Nomi
I bought these in Japan last month. The cost was around $350 for the mirror housing. You have to take the internal parts from the original mirror and put in the new housing. I had to get these painted in US since they did not have the color that i needed. they did have some already painted but only in 3 colors. I think the painted were about $100 more.
as far as having the dealer install these, i would like to do it my self. i know i will do much better job then they will. also i wanted to do a DIY for some friends that are wanting to do this.
If you will be doing a DIY, I will try to research where to get the wiring. I think you can purchase the JDM Harrier mirror with signals from one of our vendors here. But there is some modification required on the passenger side. There was a thread on this. Everyone wanted to get theirs done, too. Exactly what did you need?
I didn't mean having them installed by the dealers but asking them for advise as they have the electrical wiring diagrams and could probably tell you what you need to do. Having them installed would probably cost a small fortune. DIY is the way to go if possible. Good luck. Let us know if you are successful and may be a picture of the mirrors too.
DIYs are great, the problem typically is working out the details before you embark. The DIY spirit is to solve as you go. The road blocks are missing pre-wires or not having the last connector (dice and splice). You go through the expense and then hit the road block ... seem like a bummer. So do the homework first has been my learning and the devil is in the details.
Toyota/Lexus has paid service to look up the maintenance and wiring manuals. The link escapes me but at @$7 a day it may be very worth it.
Salim
Salim
On the other hand, you could buy a Lexus Wiring Diagram Manual on eBay for around $50-60, but if it's a one time use or job then you might not need it. Just type in Lexus Wiring Manual on ebay search.
http://cgi.ebay.com/ebaymotors/2007-...spagenameZWD1V
Ok, Nomi, check if this is waht you need. Promise to do a GOOD DIY, please.
Here's the 2nd page.
The diagrams should be what you need. Let's get this going! Lots of pics, please. This DIY, if it ever happens will also be useful for the ADD ON type LED's.....
thanks that is what i needed. Only one more question. do you or any one else knows where the is "Instrument panel J/B" located. i would think this is located under the dash in front but not sure. I will take lot of pictures. attached is the first picture of what the mirror that has been painted to match my car.
Do you have bamboo pearl?
Please give us another shot showing the guts...
Where are you located in GA? Anywhere close to Marietta?
