Hello I needed help on some wires the previous owner cut not sure why he did but he had this ****ty aftermarket alarm system I took it out already everything works fine exept my horn What are these two wires purpose?
This should be fairly easy. Match the exact color, stripe color and gauge size wires together. Join them with some same gauge high quality copper insulated repair wire, solder them and don't forget to slide some heat shrink tubing onto the re-joined connections before soldering.
Just very carefully inspect and match them. It does not look like many of these wires were broken.
