SC- 1st Gen (1992-2000)
Where did you put your gauges in your turbo SC?
Old 06-21-08, 06:37 PM
  #196
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
Originally Posted by mteele
I like a few of the setups like Curry's and 704's. But to me, a molded in A-piller mount is the only way to go. If its not easily visable during high-speed driving then the gauge does me absolutly so good.
That is true depending on what the gauges are. Most of my gauges would be more for tuning. Even Boost is not really needed once your car is set up, you would look at it if you were loosing power. Would be nice to have oil pressure in eye sight. Really, the tach and speedo are the most important and they are right where they need to be.
Old 06-21-08, 10:13 PM
  #197
J_Atreides
J_Atreides's Avatar
Originally Posted by tonyc9928
I made this myself out of a piece of pvc. I plan making another for an afr gauge and I will put it on the other side of the cluster.
Sorry, but I'm stealing this idea. PVC pipes FTW.
Old 06-22-08, 12:18 AM
  #198
twizted
twizted's Avatar
Originally Posted by na4now
Dang Scott, Im surprised. I wouldnt have just posted that. You have one of the nicest cars, here, ...but that looks like crap.
Um get off the pipe...
Old 06-23-08, 07:12 AM
  #199
tonyc9928
tonyc9928's Avatar
Steal away my friend. Glad you like it.
I'll post another pic as soon as my afr gauge gets here and I make 1 for it.
Old 06-23-08, 07:28 AM
  #200
2.5tsoarer
2.5tsoarer's Avatar
that PVC pipe trick looks pretty cool
don't really think the glove box is the best place for gauges, its bad enough they are far and to top it off they are not angled.
Old 06-23-08, 11:59 AM
  #201
gadgetSC
gadgetSC's Avatar
Here's mine. Boost, Oil Press., Tranny Oil Temp., H20 Temp., Fuel Press., Lap Times......All right in front
gadgetSC
Old 06-23-08, 12:48 PM
  #202
2.5tsoarer
2.5tsoarer's Avatar
gadgetSC
Defi came out with something similar, very nice !
Old 06-23-08, 08:58 PM
  #203
J_Atreides
J_Atreides's Avatar
gadgetSC
No offense, but sure looks clean, at the same time, dull. I guess I just like the jet cockpit kinda look... U know, gauges In Your Face kinda style...
Isn't it a pain to reach forward every time when you want to view different stat while driving?
Old 10-07-08, 02:10 PM
  #204
BigManne
BigManne's Avatar
thread bumpski. did most of you use electronic gauges or than mechanical on boost? i plan on replacing all of my factory gauges with aftermarket. speedo ,rpm, fuel, water temp, then adding boost, oil pressure and wideband. would i be able to get all the signals i need from behind the factory gauge cluster?
Old 10-08-08, 09:34 PM
  #205
BigManne
BigManne's Avatar
so anyone got any info on the signals for aftermarket gauges. can it be gotten behind the gauge cluster?
Old 10-09-08, 02:17 PM
  #206
lfrers
lfrers's Avatar
The VPC and S-AFC are in the arm rest.
Attached Thumbnails Where did you put your gauges in your turbo SC?-img_2202.jpg
Old 10-10-08, 01:45 AM
  #207
AdamLexus
AdamLexus's Avatar
Well since my original post was deleted for no reason...
here is what I am doing for gauges. Should be done with gauges mounted shortly. I am still finishing up some final things. I have Nordskog digital blue gauges going in to match my Lextech blue clusters.
Old 10-13-08, 12:35 AM
  #208
Cleanshots
Cleanshots's Avatar
^^^^^^^^^ dude thats sikk. why not also tilt them towards the driver?
Old 10-13-08, 05:53 AM
  #209
AdamLexus
AdamLexus's Avatar
Thank you
The reason being because there isn't much more room (I mean mm's) to do that. There is 4 52mm spaces. I did it that way so I could get more gauges. If wanted, we would do it with 3 and probably not be a problem, but then again, we run into spacing issues as it is a tight fit in the recessed area already.
Old 10-13-08, 08:19 AM
  #210
GZZ-TT
GZZ-TT's Avatar
What does that 4 guage pod bolt to? bolt holes that are already present in the chassis/roof, or just to an interior panel piece? I ask because I might be stripping my roof out of the SC, and wondered if it would bolt to the actual metal on the roof somewhere. Thanks
Quick Reply: Where did you put your gauges in your turbo SC?
