Sc300 wiper fluid dispenser nubs
4th Gear
Hello all,
I have a problem with my windshield wiper fluid system. In the nubs on the hood, I see two nozzles, but only one of them work on each of the nubs. I didn’t want to go poking at it with a knife without researching, but I couldn’t find anything about just those two bits not working. Any help would be appreciated thank you.
I replaced mine with a set of three-nozzle units for a Lexus LS430 (they do come in several colors-- having a black SC made this easy for me). They are a direct parts bin replacement and offer even more nozzle coverage.
Sometimes these nozzles get clogged up over time. Usually people suggest cleaning the ends out with a needle point with care.
KahnBB6 (05-18-24)
I've cleaned them out with a toothpick before to middling results, then over time as I use them they unclog themselves and get back to normal. If you carefully clean them out with a needle or similar, you should be able to unclog it at least a bit.
https://parts.lexusofsilverspring.co...8150040D1.html
https://parts.lexus.com/p/Lexus__LS-...8150060C0.html
https://parts.lexusofmobile.com/p/Le...8150040C0.html
ESCEE400 (05-21-24)
Anyone find a solution to fanning out the washer fluid?
I despise the factory SC 2 stream nozzles. Also hate the 3 stream pre facelift LS430 ones. Get a set of the ES330 misting types. Part #85381-33060. You can probably get a color close enough to match your current one.
ESCEE400 (05-23-24)
https://parts.belllexusnorthscottsda...modelYear=1993
The 2 stream part number for my 1998 400 is 85381-30060. The part number for a 1993 is 85385-30040. Dunno if it'll work, but probably will?
85381-33060-E0 for a ES330 is what you want, yeah.
ESCEE400 (05-24-24)
thanks TXMeatball, I ordered a pair and going to make them fit on if they don't already snap in place as is.
