Telescopic Steering Wheel Issue
Hey Guys I have a question about my telescopic steering wheel.
When it is set to automatically come out when I stick the key in it starts to come out but when I turn the ignition it stops. It will come all the way out if I just stick the key in and don't turn the ignition on. This is on a 92 SC300. Is this normal for this year?
My 95 SC400 would come all the way out even while I was turning the ignition on.
Any Ideas as to what I should check for?
Thanks!!
Thanks!!
Hmmm... I did a search but I could only come up with problems with it not working at all or grinding. Mine works fine as far as the motors in it go, but It seems like when I turn the ignition it cuts the power to the steering motors on it's way out.
Anyone have any ideas?
Thanks!
Thanks!
stering telescope problem
My stering wheel start to go down then stops. If I try to manualy do it it will start to grind and not move. Any idea what to do. Can i fix this myself of will I need to replace that piece that moves it up and down. Adam
if you will use our search feature for exactly what you posted as a title, you'll get the info you need. PLS use the search feature. just type in what you did for a title.
welcome to CL
welcome to CL
telescopic question and underhood paint color
New guy here
Today I looked at a 96 with 101k on it and the telescopic steering wheel didn't seem to work right. When I opened the door it moved by it self but when I got in the joy stick would not move the wheel in, out or up and down. What is that "Auto" button for? It seemed to be stuck in but I'm not sure if that's how they all are? If it is just stuck in would that cause the joy stick to not work? ( tried to search on this subject but came up empty)
Ok, next question. Do all SC's have black paint under the hood in the engine bay? I've looked at 3 so far, first was a Silver SC 300 that used to be black, second was black and the third was burgundy but coulden't tell if it used to be black or not. I did notice the door hinges were black also.
Thanks guys
Thanks guys
rvj25
11-04-16 04:43 PM
