14.08 1/4 miles !!!! YAY!
Ok, 2nd time ever at the tracks...
Orlando
Crowded as hell
2 runs only.
Mods.
1.0 bar boost
S-AFC set at almost -12% all the way across on high throttle.
3" mendrel bent full exhaust.
supra brakes
SS lines
supra wheels
Stock auto tranny
NGK 3330 (that helped ALOT)
1st run:
14.16@102.29
60' - 2.36
2nd run:
Set 5k rpm range to -15%, set 7k rpm range to -14%
14.08@102.70
60' - 2.398
I went along for the supra meet and i have decided on 2 things.
1. my car is way more comfier
2. I am sooooo putting a single turbo on this car and beat down on the BPU's
Orlando
Crowded as hell
2 runs only.
Mods.
1.0 bar boost
supra brakes
SS lines
supra wheels
Stock auto tranny
1st run:
14.16@102.29
60' - 2.36
2nd run:
14.08@102.70
60' - 2.398
I had some falken something or other (deep v cut, cheap *** tires). It was a humid day too and not too cool. I'm guessing if the temps go down then i can expect 13.9x times.
so....
next item on list
1. boost gauge
2. fluydine
3. HKS twin power
does that sound right? any other suggestions?
so....
next item on list
1. boost gauge
2. fluydine
3. HKS twin power
A higher stall converter will allow you to build more boost at the line and drastically reduce your 60ft times. The stock stall may allow a 2.1 or 2.2 at best.
auto vs 5/6 speed, its your call but what are your plans with this car?
dragstrip --- def a built auto
