gas pedal stiff?
Id check the throttle cable in the engine bay and make sure its not getting caught on anything. Also check the play on the throttle plate. There may be some deposits blocking the plate from moving freely. Pull the intake hose and spray some carb cleaner in there. That should do the trick.
Luxor
SC- 1st Gen (1992-2000)
14
11-11-10 12:36 PM
