SC- 1st Gen (1992-2000)
How to: clear the AIR BAG light
Old 06-06-06, 02:50 PM
ki_soarer
ki_soarer's Avatar
i finnaly got arround to getting mine cleared. i thought i had a switch, but it was only a two way switch. i just used bare wires and had no problems.
Old 06-25-06, 11:29 AM
twojayzee
twojayzee's Avatar
I removed my seats to install dynamat a few months ago and removed the seat belts which are tied into the srs system. The code is a 74 or 47. The proceedure to clear code 41 didnt work. Can anyone help ?
Big TIA !
Old 06-26-06, 10:10 AM
mikeloc24
mikeloc24's Avatar
Big TIA !
Let's please keep this thread about the AIR BAG LIGHT and the air bag light only. Thanks for understanding.
Old 06-26-06, 10:14 AM
twojayzee
twojayzee's Avatar
This is the AIR BAG LIGHT. Its just not a code 41. I think it could help folks that have this same issue.
Old 07-29-06, 05:10 PM
racinstyle
racinstyle's Avatar
dammit, i have to get my adapter before I do this...
Old 07-29-06, 06:33 PM
twojayzee
twojayzee's Avatar
Adapter for what ?
Old 07-30-06, 02:09 AM
racinstyle
racinstyle's Avatar
Adapter for what ?
the adaptor to connect my new airbag to my new steering wheel.
Old 07-31-06, 11:31 AM
mikeloc24
mikeloc24's Avatar
I have to get some milk tonite from the store. So I can eat my rice crispies tomorrow morning.
stuckincal (08-14-22)
Old 06-04-07, 12:01 PM
DaveMcKenz
DaveMcKenz's Avatar
Hi Siniquezu,
Just wanted to thank you. I made your switch out of an old 3-way light switch and it worked on the third try. I had tried maybe 20 times before freehand.
Old 06-04-07, 12:16 PM
twojayzee
twojayzee's Avatar
I tried 50 times and still cant get the darn thing to turn off
I think my pass side squib is bad
Old 06-04-07, 01:02 PM
JspecSC3
JspecSC3's Avatar
What if your air bag light was accidentally cut by the tire and then reconnected again? How do you clear that light?
Old 06-04-07, 01:06 PM
twojayzee
twojayzee's Avatar
The same way
Old 06-04-07, 02:01 PM
DaveMcKenz
DaveMcKenz's Avatar
I had almost given up. Some tips that worked for me:
1. Put ignition in ACC position with no contact to AB or Tc
2. wait 6 seconds by your watch
3. Contact ground wire to Tc...AB...Tc...AB for one second each. One second is longer than I thought, so use a watch to get the timing.
4. Contact and hold Tc to ground. The airbag light finally changed to rapid flickering and then went out.
5. Celebrate!
Good luck
Old 06-04-07, 02:37 PM
JspecSC3
JspecSC3's Avatar
Originally Posted by twojayzee
The same way
Didnt work.
Old 06-05-07, 01:33 PM
96sc3
96sc3's Avatar
for some reason, im getting cruise and abs light flashing when its done but the airbag is still there.
Quick Reply: How to: clear the AIR BAG light
