Door panels
Here is my question. At some point I would like to get new door panels for a few reasons. 1) the handles are cracked, I fixed and braced them and they are strong but still cracked. 2) The driver side upper trim piece had been damaged before I got it and keeps riding slightly away from the door upwards. 3) places where the screws go at the bottom are worn and too big for the screws been taken off a lot I guess.
SO if I buy the door trim does it come with both the upper and lower pieces or are they 2 seperated things ??
Some FYI for you. Those screws at the bottom of the door panel do absolutely nothing in my opinion. They are worn on my car also. I have removed and put on and removed over and over a million times already through modding my SC. And I have never even used those screws. I just screw em in anyway to provide some support. But it really don't matter because the panel actually slides up under the wood trim and screws in on both sides of the door also. That thing ain't going anywhere on you. If your looking to replace for the other reason's it will look good for a while but will eventually crack again. This car has those little things here and there that get on all our nerves. The #1 most wanted on all our lists I would think is the "WATER IN THE HEADLIGHTS". Our SC's have little people that live in them and no matter how much we seal the outside of the lights with anything you can think of. The little people just throw more water on the inside of those lights. THAT IS MY OPINION ON THE HEADLIGHTS IF YOU ASK ME
