Pure White Cold Cathode Climate Control
#46
No, the input voltage is only 12 volts plus/minus 10% which is too low for a running vehicle voltage which is typically as high as 14.4 volts.
It would probably be fine. Just letting you know that cars do not run at 12 volts.
I don't have my wiring diagram in front of me but if I recall at all (this was 5 years ago) the illum circuit is a green wire with a white or yellow stripe? OLT should know this.
Just take a test light or DMM to verify which it is.
#47
So you just discarded all the white plastic casing the bulbs and used the CCFL's feet to mount on to the board right?
#48
Yup, toss all white plastic as they are just lightpipes. I didn't have feet on my tubes so I made foam rubber bases. Whatever keeps them cushioned.
See post #2. See the black foam discs? Cushy.
#49
great info, one last question, did you have to use a solder wik to remove the solder from the lcd? i have a solder sucker would that be sufficient? i haven't soldered in 10 years and I don't want to make a mess. thanks jose!
#50
You are trying to desolder the LCD?
Has a replacement screen come out within the last 5 years my out-of-touch *** hasn't heard of?
Brush up on your soldering skills before you tackle that one. Not sure which method would work best. Try each and see which you like better.
#51
I'm not sure how long the replacement LCD's been on ebay but ever since I bought my sc in '07 it's been there already. I have it and I also think OLT saw an actual one from a customer too. It looks exactly like OEM The guy selling it has been making a killing out of it with no one else offering it.
#54
Love to bring back old threads
I have everything in place, let me tell u this, I LOVE IT ALREADY.
I have to ask CleanSC, where did u connect the power of those lights? this is because, I want FULL power to the lightsduring day time, and less than full or may be half power during night time. i do not want those lights disturb me when i am driving at night, because IT IS BRIGHT !!
Is factory setting of climate control lights will dim when parking light turned on? If not, i may wire the power brick to the hazard light if factory setting will keep the same voltage to the climate control light no matter day and night time.
#55
#56
yes, those CFLs come with 12v inverter. i just need to plug it to a power source that can provide power when the car is started. my ideas is the source i mentioned before. the only thing is, can this inverter capable dim the CFLs when parking lights is on. i guess i will find out this weekend.
#57
I wired mine into the parking light circuit. So it's full brightness at night. It's a little bright, but nothing dangerous or horribly distracting.
As far as I know these are not dimmable. If you want to do that, I suggest going with an led matrix that you'll need to custom fab up yourself. It's been many years since I originally designed this and led's have come a long way. If I was doing it all over again, LED for sure.
Good luck!
Good luck!
#58
1JZ Single SC400
Its great to see an old thread still come back to life. I am glad to hear that the lighting is still holding up... I just redid some of my interior lighting to a brighter LED. MO better now!!!
#59
Interested in this mod! So glad you guys have already done this. I googled SC300 lighting and found this thread!!! Subscribing for sure.
O.P, do you have any recent pics of your dashboard with these? Thanks in advance
-Mike
-Mike
#60
Too much work. Can get the same results with LED.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
262-456-4147
