what is code 41 on a 92 sc400
hey I've been trying to clear m airbag light for months ,followed all the threads still can't clear it ! the only code I get is 41 ,which I read on one thread ,was not on a '92 sc4 ? can anyone confirm this ..
thanks ;Dean S
thanks ;Dean S
Dean, what I need you to do is find out if the codes are the same for 300's and 400's. If they are then read on, as I got this info from a diagnostic sheet for the SC300. The DTC numbers go like this: 11, 12, 13, 14, 15, 22 (which is the airbag code I'm dealing with now), 31, then it jumps to 53, then 54. There doesn't appear to be a code 41. I can't find that anywhere. Maybe it's blinking like this: blip-blip...(pause)...blip-blip..if that's the sequence then it's code 22, not 41. Check again to make sure, as I said there's no code 41 on this diagnostic sheet. I know it's frustrating, trust me I know...I just need you to be sure
saiko2j (10-25-20)
yeh, blink,blink,blink,blink pause blink! then more of the same..
or you can call it a blip a bleep a wink or what ever your heart desires but I'm sure it's 41 !
Code 41 is the throttle position sensor signal. An open or short in the sensor circuit.
Code 22 is a water temperature sensor signal. Could be the sensor, short in the sensor circuit, or an ECU problem. More than likely the former.
