left turn signal started to blink rapidly?
i think calvin needs to read the post if your going to help and not waste time.https://www.clublexus.com/forums/sho...threadid=35134
Originally posted by Calvin L
im so sorry man, you've contracted the disease SRS (Stupid Ricer Syndrome)
get well soon
get well soon
Calvin, it was midly funny... kinda like a bad joke that's so bad, it's funny It made me smile. We've all seen those uber cool APC tails that have developed a nervous twitch instead of a blink.
Before you go and say I'm not treating you with courtesy, my tone is a reflection of yours.
Calvin didn't waste my time, he actually made a boring post on quickly flashing bulbs kinda comical.
Lex Luthor's post was about people giving truly stupid advice on subject they are clueless about... like try fixing your tranny by reving it up to redline in nutral, then at 6,000 RPMs put it into drive
Maybe you're the one that needs to read it again.
Jay, you wasted my time far more than Calvin did.
Alright, I'm done throwing pearls.
It might be a faulty bulb, or a bulb going out. My sc once had the same problem. Sometimes it'll blink really fast, but all the bulb seemed to work fine. I switched the bulb anyways and problem solved. Just change the bulb and see if the problem comes back.
Originally posted by mrshabo
i didn't get any apc bulbs... they are stock bulbs. i'm a ricer for having stock bulbs
i had the same problem a few months ago,
turned out moisture got into the taillight and rusted the bulb sockets, clean them out and check if there are any cracks in the tailight that might let moisture in if this is a problem, otherwise take the taillight off and see which bulb isnt working by turning on all the tail lights signals,etc.
If I remember correctly the early SCX00s had 3 bulbs for one purpose. When people wanted t oswitch to the 95 or 97 style lights they had the hyperblinker because the computer was missing something like 54w.
CleanSC explains everything about that problem here
0l33l
Shabo:
Sounds like a loose filament on one of your turn signal bulbs. You have one up front, and three out back.
Check them out.
The bulb will visually look okay, but the filamet may be partially disconnected and making a slight contact. It's enough to light the bub, but not enough to keep the flasher happy. Change them out one at a time until it stops.
Good luck.
Check them out.
Good luck.
Jay, we try to be friendly and cordial here, and until you've been around for a while and see how other members treat eachother (which just so happens to be with courtesy) I suggest you don't say stuff just to boost your post count and look good. We don't try to make ourselves look better at another person's expense -- that's what 7th grade was for.
jay, dont know whats wrong with you, but man...lighten up!
konacoffee
05-26-17 11:13 PM
Buttercup
03-18-04 09:51 PM
