SC- 1st Gen (1992-2000)
Heat from the firewall entering cabin
Old 07-20-04, 10:38 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
A little insight.....
When i experienced this problem i went out under the hood and manually closed off the heater core control valve and removed the arm so it couldn't re-open. Since then i have been heat free.
It seems the control valve never seems to fully close, especially if the air is off. Give it a shot, i have been very happy since i did.
Old 07-20-04, 10:41 AM
THE_CEO
THE_CEO's Avatar
It seems the control valve never seems to fully close, especially if the air is off. Give it a shot, i have been very happy sine i did.
you mean im gonna have to change it back in the winter when i need the heat up here in michigan....lol
CEO
Old 07-20-04, 01:42 PM
buggsc3
buggsc3's Avatar
Is this something that anyone can do, or would I be better off going to a shop?
Old 07-20-04, 02:21 PM
/Aerostar\
/Aerostar\'s Avatar
Takes a good solid 15 seconds. Look for the funny lookin black thing up at the passenger side firewall. I havent done it, but its easy, someone else should be able to explain the rest
Old 07-20-04, 04:49 PM
indypwr
indypwr's Avatar
Post
yup, im having this problem too..........
can anyone elaborate more of what O.LT. is trying to say in regards on that black thing under the hood?
we shud do this a sticky.........heheh
Old 07-20-04, 06:54 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Lemme get some pics
Old 07-20-04, 07:06 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Here is the heater core control valve.
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Here is a closer look...
Old 07-20-04, 07:08 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
See that metal rod under it? It connects to the unit and moves via the hydraulic action inside the cylinder. Simply remove the arm from the dome and manually move the latch on the bottom of the heater control valve. Turn your heat on in your car and if you do not feel heat after doing this, you are set and ready! Give it a few minutes to cool down since there is still heat in the core, letting the car sit a while is a good idea too just to be sure.
Old 07-20-04, 08:31 PM
VSsc400
VSsc400's Avatar
also something to consider.
turn the fan on.
turn the **** all the way to cold position
turn the fan off.
it appears even though the fan may be off if your last position was at HOT it will keep the valve open.
If you have it at full cold, it will keep the valve as closed as it can get.
I feel the difference between the two... anyone else care to try?
Old 09-06-04, 12:02 PM
aho
aho's Avatar
Default hot air bothering me!
I have a 93 Sc300 and I have a problem. When I drive my car the hot air from my engine comes in my car under neath the steering wheel on the drivers side. Which makes it miserable to drive during summer.
Anyone experience this problem or know how to fix it?
Thanks
Old 09-06-04, 12:48 PM
aho
aho's Avatar
bump
Old 09-06-04, 01:11 PM
jz80tt
jz80tt's Avatar
Its the way the car is designed. For some reason, my old MKIV has the same problem too. I guess hot air from the engine is not properly designed to escape so its circulates into the cabin. My Sc300 is like that but not nearly as bad.
leonard
Old 09-06-04, 04:48 PM
0l33l
0l33l's Avatar
Something I pulled out of my FAQ. Link
Old 09-06-04, 05:21 PM
legendary
legendary's Avatar
I have not experienced this problem, but the info that Eurojulian and OLT have shared seems like an idea for you.
Make sure your car is running in tip-top shape, and try again.
Quick Reply: Heat from the firewall entering cabin
