SC- 1st Gen (1992-2000)
Heat from the firewall entering cabin
Old 09-06-04, 05:32 PM
  #31
BLK13X
Mortgage Slave
BLK13X's Avatar
Never had this problem in my Soarer, not from around the steering column anyway. Mine's usually heat coming from the tranny but even that's not too bad.
Old 09-06-04, 07:01 PM
  #32
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
I havent noticed this in mine.
Old 09-06-04, 08:01 PM
  #33
tpham7
tpham7's Avatar
i have this same problem.
Old 09-06-04, 08:28 PM
  #34
G Star
G Star's Avatar
I dont think this problem exists with my car (maybe because I always have a/c on 1 or 2 bars) but the burning smell of my black leather isnt good either.
Old 09-06-04, 08:54 PM
  #35
Nomis
Nomis's Avatar
Don't notice it either in the SC4 - exhaust is probably routed differently too though.
Old 09-06-04, 09:25 PM
  #36
Cadd
Cadd's Avatar
I have the same problem in my GS. Seems like a lot of hot air coming from right below the steering. Passengers also mentioned that they feel warm air around the glove box area.
I guess this is good for the winter
Old 09-06-04, 09:30 PM
  #37
Lexiss_sc430
Lexiss_sc430's Avatar
Hey guys u know what's kinda funny, the boys over in the Sc430 section have a identical post going, It seems like the Sc430's have the same sort of problem, If anyone finds a solution here u might wanna pass it over to them or vice versa
Tommy
Old 09-06-04, 10:23 PM
  #38
SC300Es
SC300Es's Avatar
What VSsc400 said.
Put on the AC.
Old 09-06-04, 11:49 PM
  #39
legendary
legendary's Avatar
Merged for better processing/search results
Old 09-07-04, 04:48 PM
  #40
tarq3
tarq3's Avatar
yeah this sucks as i thought was the only one that had the issue. I think putting extra heat sheild material might be the only way to fix this. Kinda sucks but hey. Looks like design flaw. There weren't many with these cars so i gueSS it's better then a crappy Tranny
Old 07-03-06, 06:17 PM
  #41
Redskns92
Registered User
Redskns92's Avatar
Originally Posted by O. L. T.
See that metal rod under it? It connects to the unit and moves via the hydraulic action inside the cylinder. Simply remove the arm from the dome and manually move the latch on the bottom of the heater control valve. Turn your heat on in your car and if you do not feel heat after doing this, you are set and ready! Give it a few minutes to cool down since there is still heat in the core, letting the car sit a while is a good idea too just to be sure.
is the metal rod the arm?
Old 07-03-06, 07:14 PM
  #42
eskinol
eskinol's Avatar
I too have this same problem. It is not powered by the fan but from the air outside (air vents). Passing through the heater core heating the air and into the car. I feel it as I drive with the a/c off, but at a full stop its gone. I figure that the vent isn't shut all the way and could be the cause. I'll have to try that manual close and arm removal to verify. Thanks OLT, you always seem to provide very promising ideas, if not, solutions.
Old 07-04-06, 07:08 AM
  #43
ScottURnot
ScottURnot's Avatar
Originally Posted by VSsc400
unfortunatelly this seems to happen to all cars.
the cats being right underneath your feet don't help much either.
but this is normal. nothing you can do but to turn the A/C on.
I got to go with this Cat position idea, When I did my exhaust I moved them down where the air hits them. Maybe its all in my head but I think its improved.
Old 07-04-06, 12:58 PM
  #44
tarq3
tarq3's Avatar
stiLL no gOOD ideas on stoping this heat iSSue?????
Old 07-04-06, 02:01 PM
  #45
slo86
slo86's Avatar
adhesive backed reflective foil on the firewall behind the engine, exhaust wrap w/ high temp silicone paint between cats, heat sheild matting around the main cat, and heat/sound barrier around the whole tunnel.
the heat shield around the transmission tunnel helped the most, its a lot quieter inside the cabin also.
Quick Reply: Heat from the firewall entering cabin
