anyone have a picture of a sc on 20"s without drop?
my tires are on the way right now, and im interested to see how hideous my 20"s are gonna look with the stock ride heighth
also does anyone know how much most ppl charge to install springs? (or is it doable by yourself, but keep in mind me= non mechanically inclined)
thanx, not AS bad as i had thought, but pretty hideous nonetheless
-- im gonna drop it wit eibachs eventually also but there shouldnt be any rubbing considering im running 245/35/20's front and back
anyone got an answer to my other question tho?
so i got my rims on, they fit PERFECT -- they dont look much like the rims on ur bros car (i mean gap wise), they almost rub in the front for some odd reason.. And im running 245/35/20 all around, maybe that has something to do with it? or maybe theres alot of wear on my springs ? idunno, but they look great and ill post pic soon as i find a digi cam
When did you get them on? When I first got my 19's, I had rubbing. After a while the suspension adjusted and I don't have rubbing anymore.
I run the 245/35/zr20's on my car and before I dropped it, they rubbed when I turned hard. I installed the tokico blues and 1" Eibach lowering springs, no rubbing!! I love the look of the SC with 20's and a little drop, it looks mean. As soon as I get some time, I am going to get some pics of my car posted.
Originally posted by mikeloc24
Reggie, you were rubbing on 19's? What was the cause of that? Was the car slammed? 19's shouldn't rub under any circumstances unless the car is severely dropped or the wheels are too wide. The height itself shouldn't cause any problems that I'm aware of.
ok so i seem to have a LITTLE problem with rubbing. So when I turn the wheel left (i mean even slightly left just drivin.) at normal speeds (like 30+), it makes this high pitched noise, its not very loud but i believe that it must be rubbing slightly (doesent do it when i turn right because theres noone sittin over there...)
anyone have any suggestions on how to make this stop, or do u think its really not that big of a deal?
try this...
when your car is at a stand still, turn all the way right, then look on the driver's side to see what's rubbing. then do the opposite for the other side. It should give you an idea about where the contact points are. I know that with my 20's, i'm only rubbing on a full right turn.
