no cd, no antenna, no mirrors, no clue!
Hi, I am new to this board, coming over from the SC 430 board. My son has saved up and purchased a 92 SC 400 (red) and we are having a strange problem. The CD player doesn't work, the Antenna doesn't move and the mirrors don't work. I have checked the fuse (its fine), and these are all on the same circuit.
Any ideas???
GW
Any ideas???
GW
ok cd player and antenna are related...but i didnt know that that the mirrors were on the same relay..ok is you radio playing or just the cd changer not working..and what is the antenna doing?
CEO
CEO
This may help if you haven't checked it yet.
For the radio, there are two fuses. The fuse box inside the car and one in the box in the engine compartment. Make sure those two aren't blown.
Good Luck!
Good Luck!
The fuses seem fine. I changed the 7.5 for that circuit just in case. The radio works, but the antenna doesn't go up. The mirrors don't respond to the adjuster ****.
It would appear to be some sort of electrical problem, but if there is a short, wouldn't the fuse be blown?
GW
GW
ok check the connection of the mirrors...pop up the drivers side window switches and see if the plugs are pushed in and check the wires...ok antenna mast is stuck you can get a new one for about $40.00...ok and for the CD changer what is happening with that?
CEO
CEO
I read the posts re the mirror ECU. I will check this and the wiring.
The CD changer was not playing correctly (some CDs wouldn't play) and then suddenly stopped. There is no response when I push the CD button on the dash. (This is a Nakamichi system).
When I checked the fuse listing in the manual, I was encouraged to see that there is one fuse for those exact three things - mirrors, antenna and CD changer.
Perhaps there is some problem with the mirror ECU which has shorted the circuit? But why is there no blown fuse??
GW
GW
did you check the driver side armrest (window buttons)plugs?....and you need to put in a cd/dvd cleaner cd...that should take care of the cd changer...
CEO
CEO
stonewis
04-24-07 08:55 PM
