Teaser pic 3....the final chapter
suspension
I think I figured out the problem. I checked the eibach website. It says the part number for my car is 8240.140.
They sent me 8230.140
Does anyone know if my car will suffer any problems while I wait to get the right springs? Should I put the stock back on while I wait?
Former Sponsor
Re: suspension
Originally posted by reggiek
I'm very disappointed. I got the suspension parts installed today. There's only a 1/2 inch drop in back and NONE in the front. What gives...is this normal? Does it take time to drop? Did they send me the wrong stuff?
I have heard lots of people complain about the Eibach drop (meaning not low enough). I think it may be 2 things:
1. Your perception- you are around all of those FLA guys with the 1.8-2.5" drops all the time so your eye is trained to expect that sort of lowering, even if you go a little less aggressive.
2. Your tire setup: maybe if you saw a SC with 19s and Eibachs, and said, "Yeah thats good enough", it had a skinny setup, tires play a big part in stance.
Also, yes it will settle, takes a couple months.
Re: suspension
-Ken
Re: suspension
Thanks, I feel a littls better. Just have to ride around a week with the back lower than the front. Looks like the older Caddy's. Just kidding, it doesn't look as bad as that but I still don't like it.
Re: Re: suspension
Originally posted by 2jzsc3
They installed sc400 springs on your sc300?? It should be okay because sc300 and sc400 shocks call for the same number meaning that their springs should be interchangeable also. The reason why your front looks the same and your rear is lower is because the springs were designed to carry more weight from the V8 engine on the sc400. Since you have a lighter L6 engine in your 300, it doesn't have that much weight on the front end to compress the springs and make your car look lower. The V8 would've put some weight and made the car look lower. Eibach springs for the 400 and 300 should have the same or close to same spring rate for the rears. Just the fronts have different spring rates due to its weight on the front end of the 400. hope that helps, but yea, its okay to drive with these springs until the new ones are swapped in
-Ken
-Ken
Re: Re: Re: suspension
Originally posted by /Aerostar\
The V8's are actually lighter...or so Ive heard, because more parts are made of aluminum. Also they will settle, just give it time
reggie
i am truly in tears at this moment . you are actually lowered ... congrats
as johnee said it will settle not so much the springs persay but the dampers will have to find their operating range then the springs will settle as well
if you want come on over , i can get them to settle real quick with my driving style
my coilovers have already settle about 1/4 and i have only had them for about 3weeks now
you guys are all telling him to wait, but i think he's saying he's waiting for the sc300 springs to come. sc300 springs have a higher spring rate than the sc400. Both sc3 and sc4 eibach springs say that it lowers the sc at 1" although they have different part numbers and they look almost identical. Thats why even if it settles, the sc4 springs on the sc3 will not lower it as much as the sc3 on the sc3.
Re: Re: suspension
Originally posted by johnee78
DAMN!! Why?? is it too stiff , bouncy??? I wonder if the springs being the wrong ones have anything to do with that...
The main thing bothering me is this thud you feel over little bumps. Don't like the stiffness either. The stock ride was already sorta stiff but luxury. The luxury is gone. I'll give it a try when the right springs get here. If I'm not happy, check the marketplace section.
