sub mounting bracket
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
I allready had it out of the car but the only screws that i see i can not get out because of the
black ring (spacer) on the top. I cant see any other way (screws or bolts) to get it apart.
thanks
thanks
any one have any ideas. And while i am at is any one useing the jl audio IB10 sub. That is
what I was looking at but noone in thecity carries it so that i can hear it. IS it worth the money to
upgrade it?
upgrade it?
I just did this. My sub was a 10" and after I removed it from the car, I carefully pryed the black ring on top up. This is attached to the woofer so be careful if you hope to keep the woofer. Then I was able to unscrew the phillips holding down the woofer. You should be able to get the rest, email for more info or pics.
