auto tilt wheel failure
while restarting my sc 400 today, i noticed a humming/grinding sound coming from my steering wheel. after further investigation i noticed my wheel was not coming to its preset position. it moves in and out, but not up and down. i took off the covers and to and came to the conclusion the gear is either not engauging, or it is stripped. there was no prior warning of a failure. has this happened to anyone? is there a way to manually get the wheel in position? its no fun driving the car with the wheel in the up position!
im a newbie here, but any help would be greatly appreciated. i really need a quick fix fast until i can replace the motor if that is what is needed
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Keeper of the light
Even though the search button would have helped you 15 hours ago, here is some help.
Take the cover by the tilt motor off. There is a blue gear wheel, check and see if it's aligned. If not add a washer on both sides of the gear wheel and that should do it.
Hope this is of service to you.
oldyngoody
09-18-12 11:39 AM
