SC- 1st Gen (1992-2000)
Removing map light/sunroof control panel
Old 09-27-04, 03:44 AM
WestOne
WestOne's Avatar
Default Removing map light/sunroof control panel
There are two screws rolling around in my overhead map light housing. I need to take the assembly apart to get the screws out but don't know where to start. Does anyone know how to remove the assembly without damaging it?
Old 09-27-04, 11:27 AM
mikeloc24
mikeloc24's Avatar
have you tried the "search" function? Give it a try....
Old 09-27-04, 01:13 PM
vredniykot
vredniykot's Avatar
Default Re: Removing map light/sunroof control panel
first you need to take out the glass (plastic)
thin flat screwdriver and just pry it out but try not to push on beige plastic too hard or it will leave a mark
Old 09-27-04, 03:09 PM
WestOne
WestOne's Avatar
I've read your long winded suspension posts on these forums and wasn't impressed. Really, if you can't provide any help take your attitude elsewhere.
Old 09-27-04, 03:36 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
*ahem*
Old 09-27-04, 03:51 PM
mikeloc24
mikeloc24's Avatar
I gave you the best help you could get, "search" will give you much more info than lazily posting your repetitive question here. Please learn some manners...it's not the best thing to insult older members. But then again, your knowledge and judgement can't be too good if you're asking how to remove a simple piece of plastic...good luck dealing with your "loose screws"....
Old 09-27-04, 03:52 PM
vredniykot
vredniykot's Avatar
here is a pic with points where it snaps in, that's where you need to be working that screwdriver, note the two marks on top are left by me not being cautios
and the rest is held on to the roof from inside, those screws that you have rolling inside are probably the mounting screws and need to be put back in
Old 09-27-04, 04:00 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
.last warning.
Old 09-27-04, 05:19 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,275 Likes on 1,382 Posts
Guys let's keep this on topic and stop with the arguing back and forth please.
Search first is definitely always a good idea, but it's even better if the older members show the new guys how to use it and point them to the keywords / links they used to find the answer to their question
For example:
Map light remove
https://www.clublexus.com/forums/sho...p+light+remove
remove roof
https://www.clublexus.com/forums/sho...ht=remove+roof
I don't think there are all that many threads out there on this topic.
Old 09-27-04, 05:41 PM
WestOne
WestOne's Avatar
Excellent. Thanks for the help guys. I always search first but didn't find exactly what I was looking.
Old 09-28-04, 10:02 AM
mikeloc24
mikeloc24's Avatar
For example:
Map light remove
remove roof
Right on point, as usual
Old 09-29-04, 07:37 AM
Shnerez420
Shnerez420's Avatar
Do the buttons on this unit light up?
Ive never taken mine apart and mine doesnt light up so I was wondering if mine are just out or if theyr not supposed to light up.
Thanks!
Old 09-29-04, 03:59 PM
mikeloc24
mikeloc24's Avatar
Thanks!
No, the only section that illuminates is the semi-clear plastic center cover. It houses 3 lights, one "map light" and 2 "personal lights"...if you press the buttons and those lights don't come on then you just need to buy new bulbs...super easy to replace and all 3 bulbs should cost less than $7
Old 09-29-04, 06:25 PM
sc300n00b
sc300n00b's Avatar
I pulled those bulbs out and it is like no bulb I've ever seen before. A very round, weird, bulbous shape to those reading light bulbs. Anyone know the part numbers for these bulbs?
Old 09-30-04, 01:07 PM
mikeloc24
mikeloc24's Avatar
Just remove the bulbs and take them inside an auto parts store and match them up, it should take you no longer than 5 minutes (Pep Boys, Kragen, Napa, etc.). The bulbs are very common and should cost no more than $6 total. The thing you need to look for is the voltage rating, I believe the bulbs are rated at 12 volts, don't skip this step as it's very important.
Quick Reply: Removing map light/sunroof control panel
