SC- 1st Gen (1992-2000)
TOP SCxxx Mileage?
Old 06-24-06, 04:57 PM
  #211
PERRYinLA
PERRYinLA's Avatar
Wow- that's amazing.
Is this your first timing belt change?
If not, how long did you go between changes?
Old 06-24-06, 05:47 PM
  #212
DetMich1
DetMich1's Avatar
I have never babied this car, in some cases people would say my maintainance schedule was a bit neglectful at times. I have gone 10,000 between oil changes and even just added an extra quart when the oil light came on. Car still does not burn oil in excess of factory specs during a 5,000 mile interval. I remember doing a major service per factory rec at around 125,000 miles. Without checking records, I do not recall a timing belt change since then. I know, its long over due. My actual mileage is higher than what is on the odometer as I drove the car for several weeks without the guages on two occaisons while I had them off to Lextech Lighting to have the needles and backlight redone. This is one of 4 Lexus's I have owned, and presently is the oldest and highest mileage of the bunch. Based on my experience with this car and the 1990 LS I bought in 1990 I was encouraged to purchase a previously owned 2000 LX470 (just over 1 year old with 11,000 miles when purchased) and my 1998 GS400 (6 years old with 87,000 miiles when purchased)
Old 06-26-06, 09:05 AM
  #213
High PSI
High PSI's Avatar
Originally Posted by SPORTcoupe
I know the point of the thread is highest mileage SCs, but I think mine is unique in that there is 158K miles on a turboed SC.
Turbo went on at 128K miles...running strong making high 13sec passes.
~Alan
There's someone with a green SC running mid 10's on the stock 178K-or-so bottom end, IIRC.
Old 09-18-06, 02:25 PM
  #214
Psionic
Psionic's Avatar
Originally Posted by Psionic
I had 181,000 at Thanksgiving dinner last november. I just rolled 204,000 today. I have this crazy knocking sound when I take off (not xmission mount, its new), but other than that I'm good.
Just an update: I will roll 212,000 this week. Since last update, I have needed an alternator, battery, distributor o-ring (which caused the alt/batt), new driveshaft (the knocking sound), and my radiator has sprung a leak somewhere...
Other than that, the car runs great!
Old 09-18-06, 02:32 PM
  #215
JJG2005
JJG2005's Avatar
Umm, not sure if I replied to this so I'm going to reply now lol. 208,500 miles, when the stock engine was pulled at 207,900 the car ran great and absolutely no problems to report.... car still runs great, other than a few small swap-related issues.
Old 09-18-06, 03:42 PM
  #216
RSTSpeed
RSTSpeed's Avatar
Distributor O-ring caused what? Mine leaks about 1 qt. per 3000 miles, so I just keep it full.
Old 09-18-06, 03:50 PM
  #217
brand0119
brand0119's Avatar
Im still breaking mine in at 116500.
Old 09-18-06, 03:53 PM
  #218
yeti
yeti's Avatar
93 sc300 w/ 281,000. runs like a top.
  #219
-J-P-L-
-J-P-L-'s Avatar
Damn, you have a NEW SC?!
Old 09-27-06, 07:46 AM
  #220
96gti2.0t
96gti2.0t's Avatar
i have a 92 sc300 with 226000 recently bought needs a little tlc but runs very well
Old 09-27-06, 10:15 AM
  #221
Psionic
Psionic's Avatar
The o-ring will leak oil directly onto your alternator which will fry it. It's $1.50 at any toyota dealer and takes about 1 minute to change.
Old 09-27-06, 10:19 AM
  #222
Psionic
Psionic's Avatar
No major problems yet? What is your maintenence schedule look like? Is the transmission still holding up ok? Are they hwy or city miles?
Im asking because if I can mimic what you are doing, maybe mine will last that long
EDIT: Nm.. I just saw you bought the car recently.
Old 09-27-06, 12:52 PM
  #223
-J-P-L-
-J-P-L-'s Avatar
ALL SC's last that long. (unless they're totaled from a crash).
Old 09-27-06, 11:54 PM
  #224
RSTSpeed
RSTSpeed's Avatar
Good to know...
Sooooo not true. Mine is a damn lemon:
*New Engine, used with 40-50k miles (wish I knew then what I know now, it'd be TT...)
*New Trans (used, 70k miles)
*THIRD A/C Compressor amongst numerous other A/C parts (hella expensive, but finally figured out THAT problem...)
*"New" (off a wreck) Rack-and-Pinion
*Yada-yada-yada... bunches-o-other stuff.
Oh, I'm the 2nd owner and currently sittin' pretty at 184,000.
Old 09-28-06, 06:10 AM
  #225
-J-P-L-
-J-P-L-'s Avatar
I should've clarified that SC400's last that long. The only blown engine
cases I've ever read or heard about were SC300's. I don't think a Lexus V8 has ever been blown. If so, it is an extremely rare case.
As far as other problems,...of course other things will need replacing. This is true with any car that lasts long enough.
Well, good luck from now on.
Quick Reply: TOP SCxxx Mileage?
