Tail Light Problem
Tail Light Problem
Wassup guys. my tail lights are suppose to come on when i turn my head lights on but they only come on when i step on the brakes. if i drive at night ..ill probably get pulled over.. does anyone have this problem or have any solutions? (i've already checked the fuse box)
Looked at all the relays, dont know how to check if its busted. I got pulled over and got a couple point defective vehicle ticket, so needed driving lights(not brake) quick. Dx3 were you saying my car has alot of problems? If so yes, I don't seem to have luck with cars -Brett
have you checked if you have any blown fuses (under the dash), I had a corolla(AE86) that was notorious for blowing rear light fuses when racing on rainy days... brake lights worked but nothing else on the back worked. For me a fuse fixed the problem until it started raining really bad again. I just kept a stash of fuses with me. good luck
Originally posted by jnguyen
i mean what is the purpose for the tail light relay
Check ur PM
Jonny
Here is a picture of what the relay looks like. I don't know if there is a way to test the relay or not, but I know a new one is approximately $43 from Lexus.
You don't need anything special to pull it out - your hand is fine.
It is located on the drivers kick panel fusebox.
Good luck,
jonny
hey i changed the relay and all the bulbs and fuse.. but it wasnt that.. it was this big yellow electionic piece located in the trunk area. It was called Tail light failure or something like that.
Post a picturte of what u r talking about
Peace,
jonny
