SC- 1st Gen (1992-2000)
Common SC problems
Old 11-08-04 | 07:01 PM
meccanoble's Avatar
meccanoble
Default Common SC problems
after the research i've done, i seen the SC's have a common issue with power steering dripping into the alternators shortening their life span. Are there any other common problems the SC has? bad diff bearings, or whatever?
Also is this the biggest SC forum available?
Old 11-08-04 | 07:13 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Yes, any bigger it'd be SC-mart.
There are several threads titled "common problems" that you can use in the search feature for tons of good info.
(which you are aware of)
Old 11-09-04 | 08:46 AM
looper's Avatar
looper
Default power steering drippings
Could you please give me more info on this? I have noticed mine started to drip recently.
Old 11-09-04 | 11:14 AM
meccanoble's Avatar
meccanoble
there has been a common problem to have power steering fluid drip onto the alternator and kill it. Simple as that. I guess you should try to fix the power steering issue asap before it costs u an alternator.
Lexusdavee
Build Threads
05-26-14 09:49 PM
kdouglas39
12-30-13 03:32 PM
Vector
Performance & Maintenance
12-04-04 08:30 PM
stoughton910
Maintenance
09-03-02 09:26 PM
mrwolf
03-09-01 03:34 PM
