air horn installation?? for my SC
i was wondering does or has anyone installed airhorns in there SC. i just got some and wanted to know how to wire these badboys up. they came w/ a 12v compressor any help will be appreciated Thanks
-Rashed
move this thread as you wish not sure where to put it but i would like to know where i should wire them up to my SC's electrical system.
-Rashed
Use your voltmeter to determine which is your horn wire under the dash. (avoid the airbag wire!).
The horn should ground,as in most vehicles. Therefore you will need a constant hot wire and the horn wire should ground.
I was actually thinking of doing this also. The stock horn is way too wimpy IMO. But everyone i spoke to said their wouldn't be enough room in the engine bay. I think they said i needed to replace the fans with electric slim ones and then move some stuff around to make the compressor fit!
Did they come with a relay, and does anyone know if the stock horns use a relay?
So are these the big chrome ones, which fender are you going to mount them on?
If you were in Texas you could get some of those cattle horns too.
jk
When I put a set of air horns on another car, I just ran power from the old horn plug/wires, by the radiator.
jk
