Back Left Taillight
Guest
Posts: n/a
Hello Again,
Im in search of a Left Taillight for a 95 SC400 any parts sights? How Hard is it to remove the cracked one that is on now, and to place the new one on.....One more thing, you know the little piece of rubber that goes around the key hole that says "acc on" etc.. where can i find one of those?
Thanks
Thanks
It's fairly easy to remove your taillight but it must come out as a unit. Open the truck and remove the insulation and find four bolts holding the unit in, remove the nuts and your electrical connector then it should pull straight out of the car. My 96 SC400 has been hit in the rear recently, I put some 93 taillights in it because they were available but I really need a right side 96 taillight to get it back to stock. Good luck on your search.
