driver side door skin
ok guys, please dont flame the spaceman. my drivers side door handle became disconnected from the rod. can someone please tell me how to get the door skin off without any damage. i would continue to use the search engine, but im running out of time. HELP!!!!!
![Cyclops](https://www.clublexus.com/forums/images/smilies/cylonA.gif)
CEO
there are several threads on how to do this. four screws on the bottom, one behind the inside door handle, two under the armrest, two at the front side of the door. Replace little yellow clip on control arm. DONT roll down the window.
https://www.clublexus.com/forums/sho...hreadid=109384
CEO
i already rolled the window down. its back up now though. whats the damage for this mistake>?
CEO
I rolled down my window and the little arm that connects to the door handle got caught, therefore ripping it off. The whole assembly is $220 at Carson Toyota. Still didnt get the clips needed either. You cant just reattach the arm.
Yes, the clip is a dealer only item. Its only 99 cents though, so go factory. I can think of a more solid idea with tack welding a washer on one side and drilling a small hole for a cotter pin on the other.
hey spaceman did you work it out yet?
CEO
CEO
well, spaceman thinks he's finally got it under control. (he hopes!) it seems as if though the rod got a thorough bending when the ol' lady try'd to roll the window down. just found this out, and without seeing this beforehand, i didnt know what the arm should look like. anyways, i think ive got it back in its proper shape, but i still need the clip. its nighttime here, so i think ill try to fabricate something that will be stronger. any suggestions? im at some family house for the weekend with minimal tools. thanks
