SC- 1st Gen (1992-2000)
Tailights still not working
Old 11-18-04, 02:06 PM
Dx3
Dx3's Avatar
Default Tailights still not working
Guys,
After pulling the car apart I still have no tailights. I replaced the harness, relays, fuse, bulbs and they are still not working.
At this point I am considering running a wire back for my tails that is spliced into my headlights. I really don't want to ghetto it but I am clueless as to why they are still not working??
Peace,
jonny
Old 11-18-04, 02:27 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Can you hire a little dude to sit back there with a flashlight?
ok really we need more info. Let's do this the "correct way" .
Q- do you have a voltmeter?
A- if so, take the voltmeter and probe the fuses for the lights, see if there is power at both sides of the fuses. probe the rear harness. See if there is power at the rear harness. If there is power at the fuses, but not the harness, you obviously have a break in the line. Find it. You will not find the answer to the problem here on this forum, you will only find it with forum guidance (me) and your volt meter. The DMM is the only thing that can find it for you.
Old 11-18-04, 02:44 PM
aliga
Former Sponsor
aliga's Avatar
an easier solution is to rig up some mirrors, so when the guy in front of you brakes, his brake reflections will bounce of your properly placed mirrors
Old 11-18-04, 03:00 PM
Dx3
Dx3's Avatar
That is an excellent insight, and great idea!! However, I think I am going to have to go with the ltitle dude on this one!!! S, , commonly referred to as OLT!!!
Peace guys and thanks OLT - I will break out the DMM as soon as I can find it. So my next question is
WHERE THE HELL IS MY DMM!!!
Jonny
Old 11-19-04, 11:58 AM
Dx3
Dx3's Avatar
OK OLT,
I am only supposed to have power at one side of the fuse right?? I checked this with my light tester.
I have power at the fuse box. The fuse has been checked and is ok. The tailight relay has been checked.
OK, now explain to me about my DMM. I have never fully understood how to use it. I have 3 choices where to plug my red and black into.
1 - V/Resistance/m/A
2 - COM
3 - 10A
which goes where and which is not used?
Next, where do I turn my switch?
1 - Resistance ( 20M, 2M, 200K, 20K, 2k/, 200/)
2 - AC V~ (600,200)
3 - DC V- (600,200,20,2)
4 - DC mA= (200,20,2)
5 - NPN/LED
6 - PNP
Also, what number would I turn it to at each one ( my options are stated in parantheses above.)
No idea why these damn things don't come with instructions.
Eagerly awaiting your daylight reply!!!
Peace,
jonny
Old 11-19-04, 01:47 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
You don't need anything but Vdc.
COM and V plugs, no use for the 10a
Old 11-19-04, 01:58 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
look what i happen to have here (say THANK YOU EUGENE )
Old 11-19-04, 01:59 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Now, unplug this plug and probe the wires for voltage (on the side of the plug going to the front, not the tail light plug)with your headlights on. Ground the black wire from your voltmeter, and use the red one to probe each pin for voltage.
Old 11-19-04, 02:07 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Here's an example. when you hit voltage, you'll see it. (just an example, do not probe the taillight plug, probe the side of the plug going to the fuse block.)
Old 11-19-04, 02:31 PM
Dx3
Dx3's Avatar
OLT,
U da man - awesome response. Pictures helped greatly. Now please look at this picture and tell me where I should have my dial set?
Old 11-19-04, 02:35 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
dc 20
Old 11-19-04, 02:43 PM
Dx3
Dx3's Avatar
OK,
Tried it and I didn't get any readings off any of the pins.
Which is weird because my brake lights work back there??
So my next move would be??????
Thx man,
Jonny
SC XCII
SC XCII's Avatar
dx3:
I don't mean to interrupt but in case OLT is not on at the moment. The answer is DCV, 20. (DC volts, 0-20 volt scale). Like he said, black (COM) wire to car ground, probe with red wire (hooked to V, not to 10A).
Old 11-19-04, 02:46 PM
Dx3
Dx3's Avatar
Originally posted by SC XCII
dx3:
Hey man,
Any help is always appreciated - thank yo for your input! Looks like OLT just beat you to it!! But please continue to offer any input you may have as I am determined to get to the bottom of this!!
Peace,
jonny
Old 11-19-04, 04:13 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Originally posted by Dx3
OK,
Thx man,
Jonny
your foot wasn't on the brake.
Anyway,
since we know there is no power at the back, we move forward. you can start at the back and work forward, or the reverse, follow the wires and find the severed connection, or point where the plug isnt in correctly.
If i had to start giving a few idea's, i'd say find the fuse that DEFINATELY controls the tail lights and make certain the contacts on the WIRE coming out of the back of the fuse box are mating good with the fuse holder, then follow the wires from there... find out where the voltage stops.
PS- you did make sure you had a GOOD ground point for the other (black) probe on the voltmeter right?
OK.......................................GO!
Quick Reply: Tailights still not working
