how much to relocate gas tank
i am going to shave my car, this include molding body kit to my car, door handle liner, antenna, and i want to do my gas tank also..
on older cars.. like chevy impala from 1969, to fill up the gas you flip the liscense plate down and you pump gas into there.. and ive known a couple people have done it on their supra so i wonder if i can do it on my SC.
anybody know how much work is required?
Registered User
![Embarrassment](https://www.clublexus.com/forums/images/smilies/redface.gif)
you'd just be punping for about 2 seconds and have it pour all over the ground. your best bet would be to relocate the neck to somewhere inside the trunk. But then you'd be risking a nasty fuel smell inside the car if you happened to spill anything, not to mention an obstruction to an already small trunk... or even wose, a nice way to clutter up your trunk if you wanted to do a stereo install
![](http://www.tmengineering.net/images/cars/sc400_rear1.jpg)
you'd probably be better off just leaving it where it is... the fuel door is pretty smooth as it is, so it's not like it'd really be cluttering up the exterior
Not to mention, putting a filler neck inside the trunk would be highly illegal. The fuel filler neck HAS to open up outside the car. If it opened up inside, then fuel vapors could collect and any spark could blow your ride to piece and, oh, um, you with it. Keep it like it is and don't change it.
I'd say have a body shop redo the gas cap door and maybe the hinge...Make it so the seam is very small and you have to look closely to tell the door is there.
Registered User
Originally posted by Caanon
I'd say have a body shop redo the gas cap door and maybe the hinge...Make it so the seem is very small and you have to look closely to tell the door is there.
Registered User
Originally posted by siaxazn
you can always relocate it to behind the tail light and the tail light pulls to reveal the gas cap im sure most of you have seen the hondas with this mod.
your right.. i guess ill just leave the gas tank there and spend my money on something more important.. thanks for the insight.. of by the was CytrikAcyd, is that an erebuni lip on your icon?
Registered User
here's a better pic...
![](https://www.clublexus.com/gallery/data/502/13786tonight_5.jpg)
