does anyone know how to get the window up out of the door to fix the regulator
i need to fix the regulator in my passenger door, i am going to use a fix posted by OLT a while ago. the only problem is tham my door panel is stuck over the interior lock. the car was neglected for years, it is really a shame because it is beautiful, it was owned by some rich lady by the ocean and she just left it in the sun and never drove it, long story short, the plastic componets of everting are brittle, and already the plastic pieces of the door are breaking, i need some help, i just need to get the door panel off, and then maybe if there is a way to fix the cable type regulator while it is on the track, i really don't want to bend it!!! foe now that is my only choice. thanks to all who have any ideas.
i just managed to get the panel off and cleared the access port into the door, but i still cannot get to the track, the window needs to be raised out, is there a good way to do this.. thanks for your help
i cannot seem to release the glass from the regulator, i know that there is a bolt but i cannot see it, i got the screws for the rail, but can't move the window because it is still secured, i really need some help. thanks
No, you do not need to bend the track. You should be able to feel where the glass is attached to the metal bit in question. There are 2 horizontal bolts on it arranged side by side.
i made a caliper and tried it from my side, i made it before you suggested pliers, but now thw glass is still stuck on something and it will not lift up, and the regulator will not lift up either, something is jammed, but there is a piece of plastic in the bottom of the door so i know that it is a broken regulator, and it is simply not knocked off of one of the tracks....what could it be sought on??
