Removing Rear Seat
David,
Do the following,
If you are removing the rear deck or looking for spare change
The rear seat consist of two sections, the bottom part and the back part.
sit on the rear seat...now try to stand up and hold on to the lower bottom cushion with both hands. Remember to be facing the front of your car. The bottom part will snap off it's hooks. Then just remove the bottom portion carefully by sliding it away from the seat belt mechanism.
You will now expose the bolts holding the back part of the seat...take those off....take the shoulder belts and move them out of the way. The back part slides upward. Do it and then take it of.
Hope this helps,
Mind
Do the following,
Hope this helps,
Mind
