Tire size
Stock rims: original tires 225-55-16
225 is the width of the tire (how wide) measure in mm
55 is the aspect ratio 55% of the width
Diameter = (225mm X .55) X 2 + (16 x 25.4) =
16 is measure in inche 1 in=25.4 mm
You need the same diameter for the ABS to function correctly.
245-50-16 or 255-50-16 is about the same diameter with the original tires.
