Weight of SC400/300 parts (only post known weight)
Many SC owners have asked questions on weight of various parts of SC300/400 but have never been able to get sure answers.
Here I am trying to build a definite guide to weight of different parts of our vehicle.
Whatever the replies are I will update this 1st post to reflect the weights.
Please post the known weight of a STOCK OR AFTERMARKET parts.
If you know (have measured themselves) or is certain what a car part weighs (SC's only) please reply here.
Stock 92 SC400 curb weight (all fluids) weigh 3575lbs (www.edmunds.com)
Stock 93 SC400 weighed as per www.tmengineering.net 3670lbs
Stock 98 SC300 1/4 tank gas weighed as per 3590lbs dynomagic of clublexus
Make sure to credit the source where you found the information
Engine, Drivetrain & Exhaust
Stock catalytic converter = 6.8lbs each (credit www.planetsoarer.com)
stock Y-pipe from cat to center pipe = 17.4lbs (credit www.planetsoarer.com)
middle mufflers (2 cans in the rear) = 20.1lbs (credit www.planetsoarer.com)
rear muffler 13.5lbs each (credit planet soarer)
driveshaft 19lbs each (credit clublexus member vredniykot)
Wheels, Brakes & Suspension
Factory front sc400 caliper = 17.5lbs (credit www.intellexual.net)
Factory front sc400 rotor = 20lbs (credit www.intellexual.net)
Factory Supra TT caliper = 15lbs (credit www.intellexual.net)
Factory Supra TT rotor = 20lbs (credit www.intellexual.net)
TT shock, eibach spring, TT upper mount 67lbs (credit rscott of clublexus.com)
TEIN HA coilovers = 72lbs (credit www.moreboost.org)
TEIN FLEX coilovers = 57lbs (credit www.moreboost.org)
TEIN CS coilovers = 49lbs (credit www.moreboost.org)
TT sway bar front = 8lbs (credit www.moreboost.org)
TT sway bar rear = 3lbs (credit www.moreboost.org)
TRD sway bar front = 11.2lbs (credit www.moreboost.org)
TRD sway bar rear = 8.8lbs (credit www.moreboost.org)
Daizen rear sway bar = 8lbs (credit clublexus member verylost)
OEM 16x7 7 spoke w/tire = 41lbs (credit lexluthor)
TT spare w/tire + air = 38lbs (credit www.moreboost.org)
OEM steel spare = 58lbs (credit SC400-V8)
LS400 brake caliper w/pads and shims = 9lbs (creidt clublexus member OneHotSC400)
OEM struts & springs = 67lbs (credit clublexus member 1993SCTT)
OEM strut F-16lbs each (credit clublexus member 1993SCTT)
OEM strut R-18lbs each (credit clublexus member 1993SCTT)
Chasis and Exterior
Stock SC400 Hood = 60.5lbs (credit www.importfan.com)
c-wings carbon fiber hood = 22lbs (credit www.importfan.com)
OEM buper with foglights = 18.5lbs (credit www.importfan.com)
OEM bumper reinforcement bar = 8.5lbs (credit www.importfan.com)
trunk jack and tire iron = 4.5lbs (me)
Interior and Trim
OEM seat; power, heated = 74lbs (credit us.lexusownersclub.com member rabidus)
TT driver seat = 54lbs (credit www.moreboost.org)
TT passenger seat = 34lbs (credit www.moreboost.org)
Rear seatbelts - 2lbs each (credit clublexus member vredniykot)
Front seatbelts - 3lbs each (credit clublexus member vredniykot)
Sunroof assembly - 34lbs (credit clublexus member vredniykot)
rear ashtray 3.5oz credit vssc400
Electrical
Pineer CD changer w/magazine and 10 CD's - 10lbs (credit clublexus member vredniykot)
Cruise control module - 4lbs (credit clublexus member vredniykot)
ABS pump - 11lbs (credit clublexus member vredniykot)
Wiper motor assembly - 12.5lbs (credit clublexus member vredniykot)
Chasis and Exterior
Interior and Trim
Electrical
FUtom (06-03-17)
Originally Posted by One HoT SC400
The stock muffler can't be 13.5lbs, i carried them with my bare hands and they were heavy as hell...It more like 25-30lbs, don't have exactly figure..
as measured by guys at planet soarer they are 13.5lbs. can't argue with what the scale says...
Originally Posted by Nomis
The Soarer guys are Aussies - maybe that was 13.5 Kilograms which may explain it.
13.5kg = 30lbs.
you guys can go to the planet soarer site and check the exhaust measurements section if you guys find it that hard to believe.
I've got no reason to lie...
OneHot: your mufflers must have been made out of lead because no way they were that heavy lol... The mufflers off my 92SC400 felt like something like the 15-20lbs dumbells i use.
6.1kg = 13.5lbs
13.5kg = 30lbs.
13.5kg = 30lbs.
anyone measure the muffler yet?
I'd love to know the exact weight of the spare tire... I would measure but I don't have a stock spare anymore
'93 GS300 16" black-chrome alloy wheel with dunlop SP9000 sports tire: 48 pounds. 10 pounds difference alone. Consider every pound on the wheel is worth 6 pounds of dead weight, thats a substantial difference vs. any car with steel rims.
Carbon fiber hood is one heck of a difference... too bad they cant be made solid and strong like a steel one though.
great post, i'm going to try and get my sc300 down to about 3200-3300lbs. (if the car weighs ~3750).
Does anyone know the factory weight? I know i'm going to remove my AC setup, spare tire, goto some light racing seats. Those 3 things alone should drop about 200lbs. Maybe i'm stretching it but who knows =).
Anyone know what the standard gas tank weighs empty? I'm entertaining the idea of a fuel cell.
And if anyone ask, i'm making a race car somewhat =).
supra driver = -20lbs
supra passenger = -40
carbon fiber hood = -39lbs (no gas shocks)
TT brake upgrade = -5lbs
TEIN HA's = +5lbs
TT spare = -20lbs
no mufflers = -27lbs
total weight lost = 146lbs
tools -5lbs
no spare - 38lbs
factory 92 SC weight = 3575
street weight = 3575lbs - 146lbs = 3429lbs
track weight = 3575lbs - 189lbs =3386lbs
way way far way to go
Is the curb weight of the SC300 about the same as the 400 or is it less?
This is a very usefull post and as i'm stripping stuff out i'll try and put a scale in the shop and take notes to add to this thread.
Anyone know what the weight of the following is?
Gas Tank:
AC System or parts of it:
Any other big heavy items? =)
Gas Tank:
Originally Posted by vredniykot
92 SC400 drive line - 19lbs
i also have cruise control module, abs pump, seatbelt assy's laying around, if you guys need their weight i can weigh them as well
