Fiberglass Bodykit Bending
Originally Posted by AutoCoutureSC
if you want to "bend" fiberglass, you're going to break it.
what did you want to do exactly?
Originally Posted by Din
shave off some parts of the inside. thats what my body guy did to give it a better fit.
Originally Posted by stevechumo
What parts were shaved? Did your bodyshop guy shave the inner side of the fiberglass bumper or did he shave the car's bumper absorber or whatever? Will shaving the fiberglass weaken it and make it more vulnerable to breakage?
I had the VIS bodykit and its front bumper flares out on both fenders sides about 2" unnecessarily. I really wish to bend them in so it could embrace the front tires, but I'm afraid to break it. Otherwise, it looks like the catfish mouth.
Take a steel electrical pipe and cut to size. Flatten the ends with a hammer and dril a hole. Screw to the bottom of the lip and attach the other end to the body. Obviously make the pipe the proper length to locate the bumper where you need it. Fiberglass is very flexible to a point, although it highly varies on the construction, layers, and shape.
Can you push it into place with your hand without hearing stress crackles? If so, you can make these braces and you're good. It will reinforce the kit nicely anyway so it doesn't flap and vibrate at high speed.
If not, you will need to remove it, cut it up, refiberglass the rear, bondo, and repaint.
Good luck!
