SC300 question
If I was going to do some major modefication to the engine Im talking about 22psi of boost from a turbo can the automatic transmition handle it on the SC300 or is there any kind of modification to be done to the trany if so please list them thank you for your time
depends if you have an auto or a 5spd... if you have an auto... lol negative. =) mine's dying now at only 10psi from a T60-1 turbo... i'm putting in a sound performance built transmission and torque convertor, i've heard nothing but raves about them. there are other solutions, such as level 10 and other places also. expect to pay around $3500 for everything, but once its in, it'll last!
-brian
'92 turbo veilside rsp sc300
- sponsored by toyo tires & valvoline oil
'01 silver is300
- stock and damn proud
-brian
'01 silver is300
Talk to Larry at SP about their auto tranny upgrade for the 4spd in the coupe. In stock form, it only holds around 300hp, perhaps a wee bit more. The SP upgrade is around $3k and is good for 500+hp. Even a "tame" T60-1 will spin out over 400RWHP, as we can attest. The Level 10 tranny is lame, many people have problems with thier upgraded tranny. Ideally, a 60-1 would make over 460rwhp with 22psi. I'm at 10psi on stock compression, which translates to 15psi if using the low compression gasket. Calculators estimate around 400rwhp at this setting.
22lbs is pushing the ragged edge of efficiency on the 60-1, it just can't move much more air than that...
I'm looking for more flow on my system as a 12.7ET is starting to feel slow... I'm just getting used to it. I'll probably look at upgrading my turbo by sending it in to SP. They can work magic on most turbos, with hand machining, polishing, porting, clipping, etc. I'll probably swap out a higher A/R wheel as well.
The Toyomoto and SP kits end up around $6k without installation, and include basic intercooler, electronics and T60-1 or similar turbo.
Goose
SC- 1st Gen (1992-2000)
20
04-04-02 06:00 AM
