new leather
new leather
i was in the last group buy and i was wondering if anyone recieved their leather seats today because i did.
havent started on mine yet. still trying to do some interior mods. don't want to risk messing up the new leather. i'll keep ya posted when its done
installed
I have received mine on Friday and started the installation that night. Total hours took = 10 hours which included interior cleaning. I ordered the basic with two tones.
- BAD
Quality overall was average. I had four places where the thread didn’t close correctly so the string started to run. I used a staple to hold the thread from coming loose anymore than it already has. This is in the inside and not the thread around the surface so this should not affect the surface display.
More vinyl that I expected. Rear seat is all vinyl except for the insert.
Back piece for the rear seat, inner line didn’t line up correctly with the groove in the cushion so I had to do some serious pulling and adjusting to get the clip on. When I measured the length to the original, it was off by almost an inch. So now I have the dreaded wrinkle. I am hoping the summer sun will stretch the vinyl to smooth out the wrinkles.
Difference of the shade of the vinyl and leather is very noticeable.
-GOOD
New feels good and it made the seat noticeably firmer giving it a new seat feel. Front seat came out perfect with zero wrinkles.
Two tones option was a good choice for me as it made it little sportier with good match to the original panel colors.
It was a nice surprise to see an armrest cover included with the order. I have to figure out how to remove it so I need your input on how to remove the armrest.
-Recommendation
Think about what you want the finish product should look like. This is important because I kind of hesitated to peel off the original leather from the back and passenger seats. I had a small tear on the driver side seat where it gets all the wear and tear. If I had to do it over, I would have price the original replacement for just the driver seat.
I have done the Katzkin leather for a Miata I had while back but they don’t have a template for SC. So if you out to get a cover for SC from leatherseats.com, pay a little more and get the option to add more leather as this should really transform the overall feel and display.
It was a good bonding relationship with a car and brings new life to the car. I ended with broken clip removing the back panel of the front seat so advice is that you push in and down to safely remove the back panel. This is after you have removed the two screws from the bottom and the side clip removed by pushing the panel and pulling apart the side away from the seat.
Only other tricky part is removing the front bottom cushion. Four screws on four corners hold the cushion in place. To get to the back screws, the seat has to be adjusted slightly in up position. Rest is straight forward.
Invest in good work glove (one with the rubber surface would be a good idea), razor blade (few cutting and trimming), and medium size cutter to remove the clips, marker, and both screw drivers. Some imagination is requiring since the front bottom cushions have the plastic clip on strip to clip on to the metal frame. Not sure why this was changed from the original clip on style but I did some lot of trimming of the plastic and small screws to hold it in its place (over cautious?).
Overall, thumbs up and I will post a pic as soon as I get'em out of the camera.
- BAD
-GOOD
-Recommendation
like to see some pics, but my main question is did you order in the same group buy as everyone else. if so did i got screwed over. i had to pay a 100 extra for the armrests, and you said they came with it. maybe i misunderstood. i don't know. good job on the install, the sun and heat should take out some slack.
sorry. post edited. and yes i did get the center armrest included
I wonder we can get ‘group-by’ for steering wheel. One of the most recent pictures from the forum member sure does look nice. $600 a piece so if we can bring the price down to $500, I may consider.
Have fun installing and expect ‘no pain no gain' and don't forget to post the finish work. Picture attached is little dark but very shiny because of the leather treatment I put on,
nice pics so far. i got grey with black inserts. can't wait to put them in. probally will tackle it this coming week. i worked on the ls brakes today and don't want to do everything all at once, it kind of takes away from the modding craze
pics of the center armrest. wrinkles so I will have to redo it at later time. I found the screws that holds the container in place. Three screws under the carpet will allow popout of the whole container.
Nick@Autogeek
Automotive Care & Detailing
02-10-11 06:12 AM
poorguy
SC- 1st Gen (1992-2000)
48
01-24-04 07:38 PM
