is this the right price?
ok so my timing belt water pump powerstearing pump went out and also blew thehead gaskets. the price i got to get it all fixxed is 3000 is that right or no?
hmm, i was quoted a lil over 1k for the timingbelt job, thats including labor the new waterpump, timing belt, and tensioner also thats at a lexus dealer, ya for the headgaskets and ps pump, that sounds ok, u got an sc400 or 300 if its a 400 then 3k is ok because u gotta remove to heads's
Trust me - been there and done it.
Jonny
185k yeah i was thinking about getting a used motor put in, do you know how much that would run for a install?
That depends on several things.
1. Are you mid-highly mechanically inclined? If so you could do it yourself.
If not I suggest getting it installed by a reputable shop. The general quote I received was $1000 with an installation warranty - don't remember how long.
However, word for the wise. If you buy a used engine MAKE SURE they did not cut the motor wiring harness as this is an extreme pain in the *** and they will certainly charge you a whole lot more. You will have to remove a lot of stuff to unthread your old harness and put in the new.
Also, make sure you get the right 1UZ - the LS ones have a different fan setup - one of them is hydraulic and the other isn't. Therefore - save yourself the added money.
This is all speaking from experience!!
I have lots of pics of when I did it if you need them
Jonny
neostar43
23
03-16-11 05:29 AM
trackball
Performance & Maintenance
18
08-12-10 12:10 PM
