fog light conversion?
i have the directions to convert corning lights into fog lights for 92-94 scs and i have directions on how to put 97+ foglights to 92-94 scs. my question is if i was to convert corning lights into fog light conversion am i able to still tap the 97 foglight harness to the 92-94 harness? would it burn the 92-94 harness b/c the 97 takes more voltage? does anyone have the step by step instructions on how to convert to 97+ foglights and make them turn on the same time as my headlights on to my 93 sc?
i do its just that im not sure if i can run the 97 fogs and not make it burn the wires out cuz of the higher volage it needs. i mean i have the directions to convert cornering lights into fogs for 92-94 sc. its just that since the 97 needs a higher voltage, is it still possible to tap it into the stock harness w/o burning it out b/c of higher voltage.
Good luck with getting an answer to your question. I posted up a thread like this a while back. I wasnt able to get any help so I decided to go with the instructions from Intellexual.net. Just becareful though. I tried using those set of instructions and somehow ended up frying my battery from a dead short. So I then tried just wiring everything up to a separate switch with separate wiring so I wouldnt fry the harness or anything else. Just temporarily until I can get someone who has successfully done it to send me the instructions. Doing it the switch way works but the downside about it is that you might forget to turn it off when your car is off. Thats why I got the one with the super bright LED to let me know. But yeah, if someone can help you out with the right way to do this, let me know. Goodluck..
try these links
https://www.clublexus.com/forums/sho...ht=90980-11156
if the links don't work try typing: 90980-11156
Hope they help
Hope they help
2jzsc3
Lighting
04-22-04 10:32 AM
