a thudding noise from front driver side with vibration
Originally Posted by mrshabo
I have clunking noises that i'm getting fixed. Gazi's brother said it was the swaybar endlinks.
Originally Posted by London Bill
There is a lot of hardware in the rear end, could be any of the bushes causing the thud but vibration is mostly related to "rotational" items like tyres, wheel bearings, rear drive shaft, diff?
Originally Posted by VSsc400
I checked my front and rear tires and they are wearing very evenly and alignement is good.
I still have vibration
driver side front area only
I just started getting those thudding noises. I thought it was my rack and pinion at first. Like you guys said, it could be the strut. I've been using a lowering spring on a stock shock for a long time now. And when I took out the shock to put the spring on, it was too soft. So Im hoping that could be it.
Your going to need it checked out, lower arm or upper arm bushes could be worn, top mount may have gone, the shocker could be worn, swaybar bushes, wheel bearing?
I have full daizen poly bushes on uppoer lower front and rear. I know these to be good as of last alignment just 4500 miles ago but I'll have it double checked.
what do you mean by top mount?
as for shockers I have TEIN's and the dampener is tested good
sway bushes are also daizen poly bushes front and rear.
wheel bearing... how do I check for this?
thanks
Originally Posted by dwebb99
check your a-arm bushing(top and bottom) VERY CAREFULLY.
any chance it's a tranny mount? My wifes was making a "thudding" sound on the drivers side. It sounded forward of the shifter but behind the firewall. A new tranny mount cured it. It was only in specific situations it would appear. This was on a '94 SC400 w/ 120k miles. Good luck diagnosing it.
twylie
twylie
twylie
twylie
chenxingha
RX - 1st Gen (1999-2003)
04-18-11 12:54 AM
