Electric Power botton
the electric power botton on the sc400 does it seem like it work for u guyz? did u guyz feel n e different? lmk i have it but i do feel difference but just wondering wat do u guyz feel?
when you switch your tranny to power mode, it changes the shift points so that you shift at higher RPMs.. the tranny is also quicker to downshift so you always have more power on tap. i also heard somewhere but have not confirmed that it changes the ECU fuel map and ignition timings to a more agressive setup
when your car is in ECT power mode, you should see a green light on your dash light up to let you know. if you don't see this light when you are in power mode, check right under the plastic cover where the switch is located and make sure it's plugged in. i took my car to an audio shop and they forgot to plug it back in so it wouldnt work when i turned it on
if its plugged in and you still cant turn it on there may be a fuse for it but im not sure
mlinn1967
01-19-10 11:01 AM
