electrical Items not working
Originally Posted by 2.5tsoarer
a couple of months ago my windows, sunroof, shift lock all stopped working at the same time. are these linked somewhere ? do they share fuse or relay I may not have found ?
They are all linked to a fuse located under the dash on the drivers side. It is a square looking fuse that is the located in between 2 other similar fuses I believe....
I think I've got a similar problem as yours....my windows don't work but everything esle does....when the Lexus techs here hooked a power source directly to the switches, they roll up and down fine. But when they re connected everything, nothing happens. Check all the wires that are by the door hinge. I think my problem lies within that rubber boot. I may have severed wires somewhere that's causing a short.
I have the same problem - my pass window and my mirrors don't work. My mechanic thought that it was also some severed wires. But, you have to rethread all the wires out and disconnect everything at the junction block. I don't feel like bothering with that. I bought a new switch last night just in case to check that.
Again, 2.5 - it is a fuse!!
