SC- 1st Gen (1992-2000)
Electrical question...before I buy this sc400
Old 05-10-05 | 08:56 PM
V8drummer's Avatar
V8drummer
Default Electrical question...before I buy this sc400
Here's the deal, I can get a 93 sc400 with 99k miles for $6,000. It needs a couple things one is a right year strut (which he had quoted at 138 parts/labor), and he says it needs some fuses??
I guess the power mirrors, stereo, and memory lock on the seats have no power to them, but every other component does. He also says it happened right after a new battery was put in, and the mechanic knew for sure it just needs some fuses. Does this sound right to you? I don't want to but it and have to deal with electrical issues.
Old 05-10-05 | 09:08 PM
boobstar's Avatar
boobstar
I think if it were just some fuses shouldnt he just fix it first??? I would be a little weary of this. I mean a mechanic says its just a fuse but doesnt bother to replace it
Old 05-10-05 | 09:21 PM
Dx3's Avatar
Dx3
There is nothing easier on a car to replace than some fuses - so I'd be calling some BS right about now. Take 2 minutes to make the car more attractive - hmmm
I would tell him if it is the fuses then you will give him $2 for a set and he can call you when they are all put back in and everything is working
Jonny
Old 05-10-05 | 09:23 PM
boobstar's Avatar
boobstar
Take it from that guy, electrical issues can be a nightmare
Old 05-10-05 | 09:25 PM
Dx3's Avatar
Dx3
LOL Yes, trust me - they can!!
Old 05-10-05 | 11:26 PM
V8drummer's Avatar
V8drummer
Well supposedly he didn't realize the problem until he got home from the mechanics and just hasn't had time to take it in. I dropped him an email, seeing if he could try and fix it, or to take it back to the mechanic if he doesn't know how to change a fuse .
The car is a few hours away from me and I just want to be able to go down there with no regrets.
Old 05-11-05 | 12:37 AM
DoubleWhoosh's Avatar
DoubleWhoosh
Most of that electrical problem is probably from a bad memory ECU for the seats, mirrors and column. Maybe a fuse, but it is not uncommon for this to go out on these cars especially when they are older like this one.
Stereo is most likely unrelated.
TM Engineering
Old 05-11-05 | 01:47 AM
JspecSC3's Avatar
JspecSC3
Fuses are easy to replace. Just have the guy do it if he is so confident that the problem is only with the fuses. The strut sounds a bit expensive. One strut usually runs about $50 plus another $50 to install.
Old 05-11-05 | 05:13 AM
KoSC300's Avatar
KoSC300
Jonny
cmon man... fuses!?!? do exactly what jonny said above or just go buy some and put them in yourself, its not hard.
Old 05-11-05 | 02:20 PM
Jonathan o's Avatar
Jonathan o
Post
Fuse are easy to replace but let him do it. Last thing you want to do is buy a car with eletrical problems. Call him and tell him you are counting your change call you when he gets right.
opisdfagjo
Performance & Maintenance
06-07-17 05:36 PM
philz1jay
09-28-12 11:13 PM
SCThreeOO
04-05-11 04:40 PM
818sc400
04-26-08 01:41 PM
ztikmedia
11-05-02 07:54 PM
