Removing exterior window pillars
has anyone removed theExterior window pillars I'm thinking of doing them in Carbon fiber but I need them removed t to wrap them
I see the two screws inside the door but htey still seem pretty D**mn tight , are there any clips ,adhesive or something Cause There two expensive to break i know that
Greg
Greg
those two screws do not hold the black trim piece. It's glued on to the door with two vertical strips of adhesive. You will probably have to carefully pry it off with screwdrivers or something. Becareful...you can make indentations in the trim piece if you're not careful.
I recently took mine off to have them repainted black....sanded it down, primered and spray painted. I bought some automotive adhesive today and need to glue it back on soon.
or do I have to take inside part away first and pry it from outside?
I need to work on my driver side door. This thing is chipping out bigger and bigger if you just leave it alone.
pillars
Greg
Greg
Please...no more wrapping.
So are you saying those screww do not need to be removed my car is a 1995 seems to be looser with the screwws removed But I could be wrong?
the two screws fasten down a metal plate that the black trim piece is glued to. so if you take off the two screws, both the metal plate and trim piece would be "looser" but it is probably easier to pry off the trim piece with the screws in place so you don't loosen up the metal plate. this is how it was on my 95' sc300.
sorry for the poor desciption...i'm so bad at explaining things
