Importtoys? Strut bar problem?
Guest
Posts: n/a
I just installed the F. Strut Bar I ordered from importtoys and let me say first off..it wasnt an easy task to install, the bar does hit the intake manifold, which is causing some vibration and excessive noise at lower RPMs. Can anyone please help me with this?
Do you have an SC4 or 3?
I got my strut bar from Motorsports Warehouse, but I can't imagine theirs to be that much different. There should be an adjustment to elevate the bar so that it clears the manifold. I had mine too low the first time and experienced the same vibrations, but just a few adjustments on both sides and I was able to make the appropriate clearance. Another trick is to tighten the bar such that the entire middle bar is angled to clear whatever you need to clear.
good luck!
good luck!
