SC- 1st Gen (1992-2000)
Check Engine Light Code 71
Old 06-29-05, 01:45 PM
2jzsc3
2jzsc3's Avatar
Default Check Engine Light Code 71
Anyone know what the check engine light code 71 is? I have 1994 SC300 by the way. Thanks for any help.
Old 06-29-05, 01:50 PM
Cloud9
Cloud9's Avatar
egr malfunction
did a quick search:
https://www.clublexus.com/forums/sho...highlight=Code
there are some more but got lazy good luck
Old 06-29-05, 02:10 PM
mikeloc24
mikeloc24's Avatar
Ken, you most likely need a new EGR modulator (Toyota part #25870-46010), costs about $53 from Carson Toyota (dealer price $71 plus tax). The next common fail part would be the actual EGR valve being clogged with carbon, just need to remove it and clean it (carb or brake cleaner spray will do the trick).
I'd bet it was the damn vacuum modulator though, frickin' tricky little part pisses me off...hit me up if you need more info. Yay-yay.
-Mike
Old 06-30-05, 09:21 AM
2jzsc3
2jzsc3's Avatar
Thanks guys. I found out yesterday and cleaned out my EGR valve already. The check engine light is now off, but I hope it stays off.
Old 06-30-05, 09:36 AM
Cloud9
Cloud9's Avatar
lexusLO
Performance & Maintenance
11-16-11 09:46 AM
ksort86
03-13-09 03:59 PM
bangdangvn
10-18-07 05:28 PM
phollero
GS - 1st Gen (1993-1997)
05-03-07 02:27 PM
Megatron
06-22-05 09:46 PM
Quick Reply: Check Engine Light Code 71
