rewiring harness under fender
hello, i couldnt come up with anything so iw as wondering if anyone has some detailed information on rewiring the harness under the drivers side fender. thanks for any help
It's really not that much of a problem on 18" wheels. I don't have any experience with 19's but I don't really fosee too much of a problem. Are you rubbing your harness?
If so, remove your fender, and you can do one of 2 things. Drill several small holes and actually pull the harness up towards the hood, then zip tie it through the holes to hold it in place. OR you can cut the harness and extend it wire by wire and run it through the engine bay.
thanks for the help, i was looking at it and saw that some people rewired it without cutting or lengthening the wire so i was wondering how other people did it. thanks again
https://www.clublexus.com/forums/1392412-post.html
https://www.clublexus.com/forums/sho...12&postcount=3
Some info I posted onto there.
I had 18's but my car was slammed much more than what you normally see here on the board.
rpx13
10-15-08 10:17 AM
